[ Sorry if this is in the wrong sub-forum, I am unsure which one was for asking for help, and this seemed like the one ]
Hello, I am trying to install macOS Sequioa on my laptop (bare-metal install, no VM) but during the installation process my laptop suddenly reboots, and starts up again. This means I lose all my progress in installing macOS.
I have done the following steps before this happens:
  • Downloaded the vanilla image of macOS Sequoia (tried both 15.5 and 15.2) from the Vanilla Images page
  • Used balenaEtcher to write to USB
  • Replaced the EFI with the relevant modded OpenCore EFI (Notebook, Whiskey Lake) from the modded EFI page.
  • Changed Laptop's BIOS config (SecureBoot off, Intel VT-d off)
  • Plugged this USB into the Laptop and booted from it.
  • Selected "Install macOS Sequoia"
  • In the macOS Recovery Manager, erased my SSD and reformatted it to APFS
  • Then selected the install button
The installation proceeds like normal, but when the progress bar is ~70% done, the system reboots and I have to start all over.
I have tried:
  • Changing the version of macOS Sequoia
  • Changing to macOS Sonoma
  • Wiping partitions with GParted
In case it is relevant:
  • CPU is Intel i7 8th gen (Whiskey Lake according to CPUID) - Compatitable with macOS Sequoia
  • Laptop is Lenovo Thinkpad X1 Carbon
Any help would be much appreciated.
Following this tutorial, since I am very new to this:
Edited by LordOfTheTeapots
Installation pc reboots 5 or 6 times to finish.
