Hi everyone, thanks in advance for the help. I’ve almost fully managed to set up my Hackintosh VENTURA on this HP Victus e0039nl with an AMD Ryzen 5600H whit integrated graphic, and a nvidia 1650 (of course the Nvidia 1650 is disabled on macOS). Everything is going pretty well so far, but I absolutely need to find a way to control the fans, because the temperature gets too high when I’m working (I use Logic 11). I can’t manage the fans in any way. I’ve been working on this for a week and have tried many things.
There’s no option in the BIOS, apart from “Fan Always On,” which I’ve enabled, but it doesn’t offer any detailed control, so it’s basically useless. The motherboard is an HP 88EB.
Mac Fan Control says there are no fans detected, and AMD Power Gadget doesn’t show anything either. I honestly don’t know what else to try.
Can anyone help me? I really appreciate any help or information you can give me.
Edited by Egø
I'm really struggling with this machine. I can't find a solution for the fan control—I've tried many things, but nothing works. There's one small detail I'm trying to hold on to: I’ve set up a dual boot with Windows 11 and macOS Ventura. I noticed that if I boot into Windows and manually increase the fan speed, the fans stay at that set speed during the reboot process. However, they return to idle as soon as I reach the bootloader's OS selection screen.
If I could somehow raise the fan RPM to a higher value during that pre-boot window, I could then boot into macOS and even if the fans stayed fixed at that speed, it would be acceptable. Do you think this could work?
I’d love to hear the opinion of the great Maldon or any other experts in the field.
Thanks so much for your kindness and attention.
