Hello everyone, I'm having a problem installing MacOs Sonoma on my laptop. I think I downloaded the correct efi for the i3-10110u, but when I try to install it, the computer shows me the lines of code and then restarts and is in a constant loop. I ask someone please help me solve this.
37 minutes ago, joao_Rodrigues said:
Hello everyone, I'm having a problem installing MacOs Sonoma on my laptop. I think I downloaded the correct efi for the i3-10110u, but when I try to install it, the computer shows me the lines of code and then restarts and is in a constant loop. The efi file i’m using is the one i downloaded directly from the olarila website for comet lake laptop processors. I ask someone please help me solve this.
photo.zip
COMET LAKE
4 minutes ago, MaLd0n said:
COMET LAKE
ok then I chose the right one. Even so it doesn't start and only displays the lines of code and the following last lines appear to me:
 KextLog: kernelmanagerd is not active
KextLog: Loading FileSet KC(s)
KextLog: Loading Pageable KC from file /System/Library/KernelCollections/BaseSysteaKernelExtensions.kc KextLog: Collection UUID matches with Loaded KCS.
com.apple.xpc.Launchd11999-11-25 00:54:34.491016 (system/com.apple.powerd) notideferred rematching count 2
IOG flags 0x3 (0x51)
nfs Jaxt start: successfully Loaded NFS kaxt
Soon after this the PC restarts and returns to the same
