Help with EFI for OpenCore(i5-4460/RX570/H81M-K) Recent W10 updates broke the system,menu won't load
Hi everyone,
I’ve an old PC in which i've installed an Olarila prebuilt, recently, likely due to some windows 10 update, Opencore menu simply won't load anymore. I've tried replacing the EFI folder with the old ones that should've worked, at least before recent updates.
I’m looking for any support to fix this.
Thank you in advance for your help! Any suggestion or assistance will be greatly appreciated.
System Details:
CPU: Intel Core i5-4460 @ 3.20GHz (Haswell, 4th Gen).
Integrated GPU: Intel HD Graphics 4600.
Discrete GPU: AMD Radeon RX 570.
Motherboard: ASUS H81M-K.
macOS Version: Catalina (10.15.5).
Current Situation:
Boot menu won't load, instead it boot straight into BIOS.
EFI.zip
Secure boot is disabled?
