Use coffelake efi folder with video patch for u
Yes and need apply ur video patch and change smbios to macmini8,1
hey I've tried multiplying it by that and I can't and now it can't boot from USB and I think it's probably because I've changed something wrong, a space or something, for the right reason
Will you do it for me?
Check there
This hardware have support but is not easy like one common desktop.
I have seen a YouTube video where there is a person on olarila where he downloads mac os raw files and runs them on usb with balenaEtcher on usb, after which he changes the efi file with the same cpu and then after that it boots up and installs macos easily.
and he doesn't change the opencore file or anything just install it no problems with it
