JOBIANS TECHIE Posted April 13, 2025 Posted April 13, 2025 (edited) If you're having trouble getting audio to work on macOS Sequoia 15.4 Hackintosh, this fixed it for me — huge thanks to this video: Install VoodooHDA YouTube It uses a simple script to automatically install VoodooHDA, which worked perfectly when AppleALC failed. Just open Terminal and run: curl -sL https://raw.githubusercontent.com/alvindimas05/VoodooHDAInstaller/refs/heads/main/install.sh | bash GitHub repo for more details Tested on my setup — audio now works even on internal speakers. Hope it helps someone else! Edited April 13, 2025 by JOBIANS TECHIE Remove markdown
Administrators MaLd0n Posted April 13, 2025 Administrators Posted April 13, 2025 Here https://olarila.com/topic/41293-how-to-solve-audio-on-ryzentosh-amd-on-macos-sequoia/ -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
