Hello can someone help me please I installed macos in my 7th gen i3 28GB ram with IGPU leanovo desktop the only probkem I faced is sleep/hibernate which I use them on my daily basis when I sleep then awake it up it it goes to black screen, it never shows up, even I tried disable hibernate still didn't work , if anone could do anything about it please help me thanks
I used this efi "EFI.Opencore.NoteBook.KabyLake" I got this from "Hackintosh EFI Folder for All Chipsets with Clover and OpenCore bootloader with monthly updates""  on this forum "insanelymac", I tried to use "Desktop KabyLake Download " but installing failed then I had to use "EFI.Opencore.NoteBook.KabyLake"
it worked fine with everything all I changed was audio ALClayoutid to 12 thats it
I used this efi "EFI.Opencore.NoteBook.KabyLake" I got this from "Hackintosh EFI Folder for All Chipsets with Clover and OpenCore bootloader with monthly updates""  on this forum "insanelymac", I tried to use "Desktop KabyLake Download " but installing failed geometry vibes then I had to use "EFI.Opencore.NoteBook.KabyLake"
You should turn off hibernation, but need to turn it off completely and remove old hibernate files.
