Help Needed: macOS Installation Issues on Ryzen 5 5600 + RX 6600
Hi everyone,
I'm trying to install macOS on my system but I'm facing some issues. Here are my specs:
  • CPU: Ryzen 5 5600
  • GPU: RX 6600 Challenger D 8GB
  • Motherboard: B550M Pro-VDH Wifi
  • RAM: 16GB (2666MHz)
The problem:
  • On boot, only my USB installer and Windows appear as boot options—the macOS recovery option is missing.
  • When I try to boot from the USB, I get the following error: https://pastebin.com/MzBsCFyx
I've already configured my EFI and will attach it for reference.
Any help or guidance would be greatly appreciated!
EFI.zip
Check correct kernel patch for ur processor
