Pci (build 23:21:31 Sep 12 2024), flags 0xc1080
Hello, How are you ?
I have a little problems with an EFI... I found the EFI on GitHub and i do some modification on it like the SMBIOS and sync it with an new version of OpenCore and it's a special EFI for AMD Ryzen...
but when i try to start i have the following line and freeze to it (need to restart my computer all the times).
The ERROR Line :
I try to modify the 0xc2000  on the EFI to 0xc1080  this and it do this error : Pci (build 23:21:31 Sep 12 2024), flags 0xc2000
and i don't know what to do...
thank you in advance for your help and sorry for my English I am French ^^'
Here's my config :
MotherBoard : ASUS ROG Strix B550-f Gaming (Wi-Fi) II
CPU : AMD Ryzen 5 5600 6-Cores Processor
GPU : Radeon RX 570 Series
and a link to download my efi 'cause it didn't pass on the attach file :
https://drive.google.com/file/d/1QgT3tZ0RvtPB5kFoon0yw5R5gHNy-FU8/view?usp=sharing
