What processor?
It's an i3-10100T, and you plan to upgrade to an i7. You’re not sure if that will be a problem.
You got it to boot by adding AAPL,ig-platform-id. You'll send the "RunMe" output after the installation is complete.
Edited by EasyVybz
Use olarila EFI folder and change smbios to iMac20,1 and apply ur video patch. U just need it.
i switch to the CometLake olarila EFI and added my ssdt and the smbios to iMac20,1 and alos add the video patch but now im unable to boot
U don't need add ssdt.
  • Thanks 1
Thanks a lot, this seems to be working. The CPU is now showing up, but I found that the PC turns off when it goes to sleep and gets stuck on a black screen when I try to power down or reboot. If there's something I need to fix to resolve this, can you point me in the right direction?
