Hackintosh restarts randomly even on low usage.
i have a HP ZBook Studio G5 (Mobile Workstation).
I'm trying to install macOS Ventura on this laptop.
I've used your vanilla images and your provided EFI for Coffee Lake (with some modifications for sound, microphone and Wi-Fi).
But sometimes often or not the laptop restarts without any popups and after reboot it says your system is restarted because of a problem.
These are my specs:
CPU: Intel Xeon(R) E-2176M 2.70GHz
Integrated GPU: Intel UHD Graphics P630
Dedicated GPU (not working 🙂) : Nvidia Quadro P1000
RAM: 32GB DDR4
Wireless module: Intel Wireless-AC (Wi-Fi works but Bluetooth is bugged out)
And also point out that when the laptop restarts from macOS directly, the UEFI, POST Errors and says the time has got broken, please boot to your OS and set the time correctly. if the problem presises, you might need to replace the on-board battery. (not the same on windows).
What i changed on the BIOS:
- Disabled Secure Boot
- Disabled CSM (in my case is called legacy support)
EFI: https://drive.google.com/file/d/1-Gmn9uCflbs64-_F6uLh6DmAJe6l7e2z/view?usp=sharing
Edited by Erfan 2025
