Getting the same startup error screen with the specified EFi also
i did mapped USB ports with USBToolBox and added both kexts and applied kernel patches still no luck
U need edit acpi and put correct cores/threads number there
i did the correct number of cores in kernel/patch in Replace value
8 core 16 threads
B8080000 0000
BA080000 0000
BA080000 0090
BA080000 00
if its not the acpi part can you help me with it how do i do it
Remove properties for cpu in acpi. Test if u really need it.
https://olarila.com/topic/38222-how-to-create-ssdts-for-hackintosh-easy-way-with-ssdttime/
