Static Noise and Screen Goes Dark During Boot
Hello everyone 😄, I'm facing some Hackintosh issues that are driving me crazy.
I've been using this build and configuration for almost a year now, but there are still a few minor problems that I can't seem to resolve:
  1. At the beginning of the second stage of booting, the speaker produces static noise 5 times in a row. I've tried replacing multiple alcid values in the boot-args, but none of them worked without booting noise.
  2. During the second stage of booting, the screen goes dark for a while before the login page appears.
I've included my EFI folder and a recording of the static noise.
The recording starts with the startup chime, and you can hear the noise starting at the 16-second mark.
I'm not a native English speaker, Please forgive my clumsy English~
My system:
  • os version: Sonoma 14.7 (23H124)
  • MSI PRO B760M-P DDR4
  • Sapphire AMD 6650XT 8G
  • Intel i5-13490F
  • Kingston FURY Beast 16GB 3600MHZ DDR4 x 2
  • WD SN770 1T
recording:  https://easyupload.io/z8xiz5
EFI: https://easyupload.io/h5axea
Edited by kiangti
U can remove device Speaker, common name in ACPI is Device SPKR _HID PNP0800
Example bellow
Quote
Device (SPKR)
                    Name (_HID, EisaId ("PNP0800") /* Microsoft Sound System Compatible Device */)  // _HID: Hardware ID
                    Name (_CRS, ResourceTemplate ()  // _CRS: Current Resource Settings
                        IO (Decode16,
                            0x0061,             // Range Minimum
                            0x0061,             // Range Maximum
                            0x00,               // Alignment
                            0x01,               // Length
Example bellow
Thanks for your help, But I can't find a device named SPKR or PNP0800 in my DSDT. Additionally, my speaker is an external speaker.
Here is my DSDT: https://easyupload.io/8yocxp
