Perfect Hackintosh on GIGABYTE Z890 AORUS PRO ICE with Intel Core Ultra 7 265K
Bonjour Maldon;
J'ai la même carte mère, mais j'ai des problèmes avec le contrôleur NVMe lors de l'installation de Tahoe.
J'ai téléchargé l'EFI pour l'Intel Ultra Core depuis le site Web. Je peux virer Seqoia et Sonoma, mais pas Tahoe. Avez-vous une solution pour le contrôleur NVMe M.2 - PCI-E 5.0 et le RTL8156 ?
Merci pour votre aide.
Just work fine. No support for lan 5g.
Disable this SSD via Device Properties or ACPI.
Hello MaldOn;
I installed Seqoia, which works well. However, I'm having NVMe Assert issues with Tahoe. Is there a solution for the NVMe controllers?
No problems about nvme on Tahoe
Hi MaLd0n,
Sorry to bother you, but I'm still having trouble installing Tahoe. I'm getting this error: AppleNVMe Assert failed (0 ≠ data). How can I fix this? Thanks in advance.
Seqoia works perfectly.
Use other weg kext
Use my efi folder
@MaLd0n da seleçao de EFIs disponiveis qual é a indicada ?  não vejo Arrow Lake , já testei com a Alder Rapter mas não dá boot , agradeço alguma ajuda , obg.
Z97X - Gaming 3 Gigabyte 32G Ram AMD 570 Sequoia - Win11 - CachyOs
Mac Mini M4
Hello MalDon, I managed to boot Tahoe with the SMBIOS iMac20.2 but no DRM. I can also boot with Macpro6.1 and DRM ok. But I can't boot with macPro 7.1. How to solve this problem? Thanks in advance
Edited by Nouri91
