I have been using the Hackintosh since macOS sequoia launch i.e June and I used eft files custom made for my laptop and processor since then I was able to use bluetooth it worked for a week and after that it stopped working till now I have been finding solutions changing the macOS versions downgrading it upgrading it and could now find any solutions
My Bluetooth is of Realtek ( saw this in device manager in windows )
as far as I know that Realtek wifi adapter does not work Mac so I am use external adapter but for bluetooth it worked for me so there might be solution to it
here is from system report
  Bluetooth Controller:
  Address: NULL
  State: Off
  Chipset: BCM_4350C2
  Discoverable: Off
  Firmware Version: v0 c0
  Supported Devices: 0x392039 < HFP AVRCP A2DP HID Braille LEA AACP GATT SerialPort >
  Transport: USB
  Vendor ID: 0x004C (Apple)
from hackintool
01:00.0 10EC C82F 17AA C02F Disabl Realtek Semiconductor Co., Ltd RTL8822CE 802.11ac PCIe Wireless Network Adapter Network controller Network controller /RP09@1D/PXSX@0
r/hackintosh - Bluetooth Issues on Hackintosh r/hackintosh - Bluetooth Issues on Hackintosh
These are kexts that I have installed
All those adjustments listed in the page are already done and still not working ,, as I mentioned it was working but after that it stopped working . Tried resetting multiple installations of other versions changing of eft files etc
If dont work dont have support
it worked when reseted nvram like for 2 -3 boots bluetooth was working after that it is not working , then I reseted nvram it worked for 1 time and while I was using Hackintosh it stopped and is not turning on tried multiple times resetting of nvram and sudo pkill bluetoothd
-btlfxbeta is there for Sequoia?
bootarg
Just add there
