I bought a cheap off brand Chinese RX580 a while back but it turns out that the device ID in the vbios of the card is not correct for use in a hackintosh. Ok, so I reflashed it. It will work but then it freezes up. I’ve checked the card out using OS X Monterey, Windows 10. The funny thing is this card shows up correctly in Monterey and Windows but still will freeze at various times.
1. What resources does this forum have for dealing with this ?
2. Is there a vbios dump from a good known working RX580 that I can use to reflash it ?
3. If I am forced to, I was thinking to buy another RX580 but one from Sapphire or Asus, one that has the correct device ID in the vbios, dump that vbios and reflash the non working card with that.
Maldon, do you or anyone else have any suggestions on how to solve this?
Thanks,
Gola1
What smbios do u used?
