Any help with prebuilt EFI for HP Pro C640 Chromebook (i5 10310U, Intel UHD 620, 8 GB DDR4) ?
I would really appreciate if someone can help me with the prebuilt EFI or extended help to setup an EFI for HP Pro c640 Chromebook.
It has i5 10310U processor ( Intel UHD 620 graphics) and  8 GB DDR4). The issue seems to be 64 GB EMMC storage. But IF the EMMC storage is an issue, I am ok with external Hard Disk storage.
I would really appreciate a prebuilt EFI or your extended help to create one EFI for this device. I have gone through some guide, but little confused. I tried prebuilt comet lake EFI, but didn't even reached to recovery.
Edited by SJ Appoos
No support for this igpu
On 11/19/2024 at 5:56 PM, MaLd0n said:
i tried this. I tried the comet lake EFI folder. I was not able to reach even the recovery page. It was getting stuck at applecredentialmanager. Is it because of USB ports? this device doesn't have USB 2.0. It has 3 or 3.1 type usb A. I am trying to install it on an external disk. It is a chromebook, but with MrChrombox coreboot, I managed to install windows 11. But my preference is MacOS. I would really appreciate your help.
