Hi guys, im found old script from AppleLife.Ru and when run create a pkgs to install VoodooHDa.
It's very nice and easy to use. Just put the last kext version and VoodooPerfPane app inside folder.
Important you change VoodooHDA.kext from ziped folder to your VoodooHDA compiled or last version from GitHub
Open Terminal in macOs and type:
sudo -i
password: ****
cd  <drag your folder with scripts>
drag  makeInstall.sh and type enter
its done!
Now just run VoodooHDA.pkg
Works to me for Clover and Opencore.
Check SIP recommended
* SIP  Clover  0x0A85
* SIP Opencore  850A0000
Zip files:
VodooHDA Installer kext 3.0.2 from github.zip
VoodooHDA Kext  3.0.2 Git Hub
YouTube tutorial VoodooHDA Sound kext Installer Patcher
Update: Thanks to  @MaLd0n for improved better tutorial
Edited by max.1974
  • Like 2
Gigabyte Aorus Z790 Elite AX / Raptor Lake 13th Intel® Core™  13900K / AMD AORUS RX 6900 XT  2 rev. / Lenovo E470 i5-7200-U Kaby Lake iGPU intel HD620 64 GB Ram / ASUS Prime B365M-K Desktop intel i3-Coffe Lake / ASUS Sapphire Nitro+ AMD RX 580 4GB / Gigabyte B360 i5-Coffe Lake / RX 64 Vega OC Gigabyte / Gigabyte B660 Raptor Lake 13th Intel® Core™ i7-13700K  / Nvidia GeForce GTX 3060 Gainward 12GB /  Gigabyte Z170 XP SLi  Intel® Core™ i7  iGPU /  Mac mini M4 Pro 12/16  24 GB Ram  512 GB Nvme /   MacBook Air 2020 10th Ice Lake Intel® Quad-Core™ i7-1060NG7 T2  Iris Plus Graphics  /  Clover Hacky Color 5161  / Opencore 1.0.4 /  God Bless you!
AppleAlc is updated and work now.
