USB Sequoia Installation does not proceed
Greetings to everyone, I have a strange problem with the installation from the USB it starts but after choosing the disk where to install it does not proceed, the classic display in a verbose way.
The disk seems ok I tried with usb Sonoma and it proceeds
I tried with two different USB
The efi of the usb is correct (efi olarilla oc kabylake update config, kext and oc), it comes to the choice of the disk and can start a beta version that I have on another disk, even the efi postinstall does it
I downloaded sequoia from the App Store, from OCPacher and from gibMacOs but I always have the same situation, after choosing the disk and "continued" nothing happens. does anyone have any suggestions,maybe an OC configuration or a kext?
thanks in advance
What hardware? Processor, mobo, nvme and gpu?
OC, Kext and drivers are updated. I attach the efi Config, Sonoma installs and starts. I updated from Sonoma to sequoia and starts the disk. I tried two usb with two official 15.0 from different sources, they don't advance after the choice of the disk while previously with the beta versions it installed and started regularly?
config.plist.zip Screenshot 2024-09-22 alle 04.25.17.zip
