Fujitsu U727 with I5-7300U - how to build a working EFI ? | Kaby Lake
Hello,
I tyed with "OpenCore Configurator" Version 2.76.2.0
Tools -> EFI Maker
CPU Family:
Select: Laptop -> KabyLake
Options:
UEFI Settings
X64 architecture
Release distibution
SMBIOS:
MacBookPro14,1  I5-7300U
The EFI starts boot but keyboard did not work -- after the Boot starts automatic the MacOS Installer
got the Error:
support.apple.com/mac/startup
If open the URL:  https://support.apple.com/en-us/101666
Did not find help in this desciption
Have a USB-Key with OSX 14.6.1 / Sonoma Installer.
The USB-Key is OK because did Install with this key another Notebook with this key.
I tryed this EFI from the
But did not work for me ....boots but the Touchpad is not working
So I try to use a USB Mouse.
Edited by maciii
Use Olarila EFI folder and solve trackpad problem.
I have no idea in this case.
First things is check on Windows what trackpad. I2C or PS2.
@MaLd0n
thanks...
sorry but where I need to copy the dSYM folder ?
Got this error... if copy & overwirte VoodooPS2Controller.kext  in the folder: EFI/OC/Kexts/
and safe the config.plist   in the OpenCore Configurator 2.76.2.0
see attach please
Error_ScreenShot.zip
Edited by maciii
May I found it !
Open OpenCore Configurator (OCC) -> Tools Mount EFI
Open EFI/OC/config.plist
go to Kernel
Disable: VoodooInput-Plugin
right window, rigt click at the mouse  -> Add set of of kext from Database -> PS2Keyboard Driver
Overwrite EFI/OC/Kexts/VoodooPS2Controller.kext
Scan/Browser choose: EFI/OC/Kexts
Safe the EFI/OC/config.plist and reboot
U need remove voodooi2c kext and aftrher that stay with VoodooInput from appleps2 kext enable
