hd4600 mobile and clover stuck on missing...
Hi firt at all, I would like to thanks this distribution to its creators.
My laptop specs is a lenovo b5400 a haswell 4th generation specs with a hd4600 mobile GPU.
I bypass haswell reboot but I dont match a gpu setup in order to make an installation with clover boot.
Im a newby at hackinstosh but I spent a week trying to install on my laptop this distribution with no luck Im stuck on first setup on missing bluethooth Controller Transport message.
Cause I read it is a gpu problem i tried a lot of flags combinations
IGPEnabler= Yes / No
IGPlatformID=0x0a26000a
Intel Graphics (some strings)
IntelAzulFB tried also 1-12
GraphicsEnalbler Yes/No
I also deleted some intel kexts
Please help me, I would like to setup it on my laptop
thanks in advance
u can try this kext ...
https://bitbucket.org/RehabMan/os-x-fake-pci-id/overview
and remember Olarila is not a distro.. is the original image with some kext and boot loader .. prepared to boot os x..
also what is installed is chameleon or clover.. so take care the boot flags u use .. chameleon don't use the same flags .. chimera use.. and read the several information here in forum to help what u try to achieve
