How to mount EFI partition on Sequoia
If you are facing problems mounting the efi partition on sequoia, this tutorial is for you!
-Problems with Paypal HERE
-Installation Guide HERE
-Hackintosh EFI folders HERE
-Hackintosh USB Remap HERE
This tool provide by chris1111 is a easy way to mount EFI Mount-MSDOS-Partition.tool.zip
1- Open terminal and list disks with command bellow. Check correct number for your case. For me is disk0s1. Check image bellow
Quote
diskutil list
2- Create a mount point.
Quote
sudo mkdir /Volumes/efi
3-Mount EFI partition. Change command to correct disk number.
Quote
sudo mount -t msdos /dev/disk0s1 /Volumes/efi
Big thanks to @max.1974 and Apple
  • Like 2
  • Thanks 1
You are the Master my friend @MaLd0n !! Big Thanks too!!!
Gigabyte Aorus Z790 Elite AX / Raptor Lake 13th Intel® Core™  13900K / AMD AORUS RX 6900 XT  2 rev. / Lenovo E470 i5-7200-U Kaby Lake iGPU intel HD620 64 GB Ram / ASUS Prime B365M-K Desktop intel i3-Coffe Lake / ASUS Sapphire Nitro+ AMD RX 580 4GB / Gigabyte B360 i5-Coffe Lake / RX 64 Vega OC Gigabyte / Gigabyte B660 Raptor Lake 13th Intel® Core™ i7-13700K  / Nvidia GeForce GTX 3060 Gainward 12GB /  Gigabyte Z170 XP SLi  Intel® Core™ i7  iGPU /  Mac mini M4 Pro 12/16  24 GB Ram  512 GB Nvme /   MacBook Air 2020 10th Ice Lake Intel® Quad-Core™ i7-1060NG7 T2  Iris Plus Graphics  /  Clover Hacky Color 5161  / Opencore 1.0.4 /  God Bless you!
10 minutes ago, caesersalad said:
Thank you!
Beta 6 fix this problem!
Yes, with 15.2 I do just
sudo diskutil mount EFI
1. i5-13400, MSI PRO B760M-P DDR4, BIOS 1E, MSI RX570, ALC897 (VoodooHDA), Tahoe 26.3, Sequoia 15.7.4, ArchLinux, Clover 5170
2. ASUS X200CA, Pentium 2117U, 4GB, HD2500 (Software OpenGL), Mojave 10.14.6, ArchLinux , Clover5162
3. Huananzhi X79M-PRO, Xeon E5-2650v2, RX570, ALC887, RTL8111F, macOS 12.6, 10.14.6, Win10, multiboot by Clover 5150
4. GA 965P-S1, E6300 Conroe, Radeon HD5570, ALC888, OS⌘ 10.11.6 (15G22010), Clover 4928. Still working.
Yes. Seems just a bug in previous. 😄
