Vanilla Hackintosh EFI OpenCore Gigabyte Z690 AORUS XTREME
-Problems with Paypal HERE
-Installation Guide HERE
-Hackintosh EFI folders HERE
-Hackintosh USB Remap HERE
Download EFI Folder HERE
How to download with Linkvertise
We're all here to have fun and learn from each other! That's all Folks!
Credits:
  • Like 2
will switch from ASUS TUF gaming Z690 wifi d4 to Aorus Xtreme Z690 for my hackintosh (thunderbolt needed on my computer), will this EFI unable all the functionalities of the motherboard ?
Thunderbolt, both ethernet port, wifi, bluetooth ?
can i use it for install Sonoma ?
thanks for your work and your answer
Edited by ElMute ODN
Yes. Work!
If u have a 10g lan need activate. TBH HotPlug need fix too.
awesome, thanks for your quick answer
don't have 10g LAN, but TBH hotplug will be needed, off chance, do you have a link with the fix ?
looking forward to test it, had better results on my hackintosh with my old gigabyte Aorus Z490 than my current Asus
so get back to Aorus 🙂
On 10/2/2024 at 10:07 PM, MaLd0n said:
Hi MaLdOn,
do you have any other references of thunderbolt Motherboard to do a stable Hackintosh
thinking to perhaps switch to Z790 during my set up move, but Gigabyte Xtreme X is out of my budget (can only affoard Xtreme Z690)
on my side best results hackintosh was with Gigabyte motherboards, but if you have some proposition of other references, would be great
I will stay with my 12900k for know (but upgrade to 14900k in the next few years is probable), and will switch from DDR4 to DDR5 with the new thunderbolt motherboard
