The USB raw images have an EFI partition with Clover, so you can format (or just mount) the EFI partition of your HD (replace X by the HD number)
diskutil list
sudo newfs_msdos -v EFI -F 32 /dev/disk[color=#FF0000]X[/color]s1
mkdir /Volumes/EFI
sudo mount_msdos /dev/disk[color=#FF0000]X[/color]s1 /Volumes/EFI
mount the EFI partition of the USB (replace Y by the USB number)
mkdir /Volumes/EFI1
sudo mount_msdos /dev/disk[color=#FF0000]Y[/color]s1 /Volumes/EFI1
and copy EFI folder from EFI1 to EFI.
Then
Boot from the pen drive again. In Clover menu, go to Clover Boot Options and select Add as UEFI boot option. Now you will be able to boot Clover from EFI partition without the pen drive, in UEFI mode.
Configure config.plist according to the wiki
http://clover-wiki.zetam.org/Configuration
After you configure config.plist for power management, you can remove Disabler.kext from EFI/CLOVER/kexts/10.X, as well as other kexts you don't need (or that you have installed in /System/Library/Extensions)
http://Olarila.com/forum/viewtopic.php?f=28&t=1703
