I have successively installed the 3 beta versions of Sequoia (Olarilla editions), and each time everything works fine except for the audio.
Here is my configuration:
- Motherboard: Z390 I AORUS PRO WIFI (rev. 1.0)
- Processor: Core i5
Audio: ALC1220-VB Enhance 114dB(Rear)/ 110dB(Front) SNR in Microphone with NICHICON Audio Capacitors
I specify that I tested several boot-args (alcid=xx) but without success..
How to fix this problem? Thank you in advance for your help.
config.zip IOREG.zip
Edited by webamri amri
Thank you MaLd0n. I managed to solve the problem by modifying the boot-args of the nvram as follows: -v alcid=11 keepsyms=1 debug=0x100 -revbeta -lilubetaall -wegbeta -vsmcbeta watchdog=0 agdpmod=pikera dk.e1000=0 e1000=0
