plz help me with this.
i havent used opencore mod.
i used github efi folder.
attaching my runmr app dump.
plz correct the folder with opencore mod and DSDT patch.
my configurtation is
HP z440
e5-1620v4
192GB ddr4 ecc ram.
2tb nvme ssd
thanks for your patience.
Send me kartiks-iMac-Pro.zip
Edited by kar2wlan
Test this efi folder then save one ioreg
EFI 01.zip
