mikeyworx Posted July 5, 2024 Posted July 5, 2024 (edited) Greetings everyone I need help on fixing my Ventura which could be almost perfect only FaceTime and iMessage is the mest I already tried couple of methods in the internet but none of them works, I have en0 built-in ethernet port by my motherboard. if I tried to login in iMessage it won't stay for long just 10 sec and it will log out automatically and the FaceTime won't login, anyone can check what is the problem ? I am wiling to buy you a coffee for a fix thank you so much Specs: INTEL i5 10400| ASUS H510M-K2.0 AMD RX 550 LEXA PRO VENTURA Edited July 5, 2024 by mikeyworx TAG
Administrators MaLd0n Posted July 5, 2024 Administrators Posted July 5, 2024 Generate new smbios with serial https://www.olarila.com/topic/39699-how-to-generate-smbios-and-serial-for-hackintosh-easy-way/ -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
mikeyworx Posted July 5, 2024 Author Posted July 5, 2024 2 hours ago, MaLd0n said: Generate new smbios with serial https://www.olarila.com/topic/39699-how-to-generate-smbios-and-serial-for-hackintosh-easy-way/ i already did this several times using iMac20,1 multiple methods and nothing works ?
Administrators MaLd0n Posted July 5, 2024 Administrators Posted July 5, 2024 U can try generate new and run this app by @cyberdevs https://olarila.com/files/Utils/iMessage Fixer.app.zip 1 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
mikeyworx Posted July 6, 2024 Author Posted July 6, 2024 21 hours ago, MaLd0n said: U can try generate new and run this app by @cyberdevs https://olarila.com/files/Utils/iMessage Fixer.app.zip Still wont work mate, Btw i dont have wifi adapter or active iphone unit atm. But tried my account on other mac pc and its working on imessage and facetime without any error, Can someone have any idea or experience how to fix this ? Its been month already tried fresh install
Trijal Posted July 6, 2024 Posted July 6, 2024 9 hours ago, mikeyworx said: Still wont work mate, Btw i dont have wifi adapter or active iphone unit atm. But tried my account on other mac pc and its working on imessage and facetime without any error, Can someone have any idea or experience how to fix this ? Its been month already tried fresh install Just use GenSMBIOS from github by downloading the zip from master branch and keep generating SMBIOS and keep checking with apple coverage. If it says that the serial number isn't valid, just keep repeating and at one point, you will get your SMBIOS. Also make sure to take a screenshot of it right away after you checked that it is a real SMBIOS. Consider donating to me through Ko-Fi if you appreciate my work here!?
mikeyworx Posted July 7, 2024 Author Posted July 7, 2024 (edited) 7 hours ago, Trijal said: Just use GenSMBIOS from github by downloading the zip from master branch and keep generating SMBIOS and keep checking with apple coverage. If it says that the serial number isn't valid, just keep repeating and at one point, you will get your SMBIOS. Also make sure to take a screenshot of it right away after you checked that it is a real SMBIOS. already tried this for a countless times but nothing works on my end Screencast2024-07-07 14.32.18.MP4 this is my problem for a long long month it keeps on looping sign in and wont sign in permanently. Edited July 7, 2024 by mikeyworx
Trijal Posted July 7, 2024 Posted July 7, 2024 15 hours ago, mikeyworx said: already tried this for a countless times but nothing works on my end Screencast2024-07-07 14.32.18.MP4 528.32 kB · 0 downloads this is my problem for a long long month it keeps on looping sign in and wont sign in permanently. Send me your full EFI. I'll try troubleshooting. Consider donating to me through Ko-Fi if you appreciate my work here!?
mikeyworx Posted July 7, 2024 Author Posted July 7, 2024 2 hours ago, Trijal said: Send me your full EFI. I'll try troubleshooting. this is my EFI https://drive.google.com/file/d/1-DrIXiixMJyUdY7OscjJMuqSyf9W61Tu/view?usp=drive_link thank you for your assistance, im glad someone will take a look into it i will return the favor once completed thanks mate i also got this error in logs of hackintool (kernel) 2024-07-08 07:29:38.299061+0800 localhost kernel[0]: (AppleKeyStore) AppleKeyStore:3467:122: user 242107cb1a384ed29542b7c4f262cfd6 unlock failed (-5) 2024-07-08 07:29:38.299074+0800 localhost kernel[0]: (AppleKeyStore) AppleKeyStore:12143:122: operation failed (sel: 75 ret: e00002ce, -1, 100000) 2024-07-08 07:29:38.567275+0800 localhost kernel[0]: (AppleKeyStore) AppleKeyStore:3467:122: user 242107cb1a384ed29542b7c4f262cfd6 unlock failed (-5) 2024-07-08 07:29:38.567290+0800 localhost kernel[0]: (AppleKeyStore) AppleKeyStore:12143:122: operation failed (sel: 75 ret: e00002ce, -1, 100000) 2024-07-08 07:29:38.834076+0800 localhost kernel[0]: (apfs) tx_flush:1241: disk1 xid 34717 tx stats: # 980 finish 992 enter 414 wait 37 32765us close 488us flush 8721us 2024-07-08 07:29:47.654481+0800 localhost kernel[0]: (AppleKeyStore) AppleKeyStore:3467:122: user 242107cb1a384ed29542b7c4f262cfd6 unlock failed (-5) 2024-07-08 07:29:47.654493+0800 localhost kernel[0]: (AppleKeyStore) AppleKeyStore:12143:122: operation failed (sel: 75 ret: e00002ce, -1, 100000) 2024-07-08 07:29:47.757214+0800 localhost kernel[0]: (AppleKeyStore) AppleKeyStore:3467:122: user 242107cb1a384ed29542b7c4f262cfd6 unlock failed (-5) 2024-07-08 07:29:47.757231+0800 localhost kernel[0]: (AppleKeyStore) AppleKeyStore:12143:122: operation failed (sel: 75 ret: e00002ce, -1, 100000)
Trijal Posted July 8, 2024 Posted July 8, 2024 7 hours ago, mikeyworx said: this is my EFI https://drive.google.com/file/d/1-DrIXiixMJyUdY7OscjJMuqSyf9W61Tu/view?usp=drive_link thank you for your assistance, im glad someone will take a look into it i will return the favor once completed thanks mate i also got this error in logs of hackintool (kernel) 2024-07-08 07:29:38.299061+0800 localhost kernel[0]: (AppleKeyStore) AppleKeyStore:3467:122: user 242107cb1a384ed29542b7c4f262cfd6 unlock failed (-5) 2024-07-08 07:29:38.299074+0800 localhost kernel[0]: (AppleKeyStore) AppleKeyStore:12143:122: operation failed (sel: 75 ret: e00002ce, -1, 100000) 2024-07-08 07:29:38.567275+0800 localhost kernel[0]: (AppleKeyStore) AppleKeyStore:3467:122: user 242107cb1a384ed29542b7c4f262cfd6 unlock failed (-5) 2024-07-08 07:29:38.567290+0800 localhost kernel[0]: (AppleKeyStore) AppleKeyStore:12143:122: operation failed (sel: 75 ret: e00002ce, -1, 100000) 2024-07-08 07:29:38.834076+0800 localhost kernel[0]: (apfs) tx_flush:1241: disk1 xid 34717 tx stats: # 980 finish 992 enter 414 wait 37 32765us close 488us flush 8721us 2024-07-08 07:29:47.654481+0800 localhost kernel[0]: (AppleKeyStore) AppleKeyStore:3467:122: user 242107cb1a384ed29542b7c4f262cfd6 unlock failed (-5) 2024-07-08 07:29:47.654493+0800 localhost kernel[0]: (AppleKeyStore) AppleKeyStore:12143:122: operation failed (sel: 75 ret: e00002ce, -1, 100000) 2024-07-08 07:29:47.757214+0800 localhost kernel[0]: (AppleKeyStore) AppleKeyStore:3467:122: user 242107cb1a384ed29542b7c4f262cfd6 unlock failed (-5) 2024-07-08 07:29:47.757231+0800 localhost kernel[0]: (AppleKeyStore) AppleKeyStore:12143:122: operation failed (sel: 75 ret: e00002ce, -1, 100000) I can't access your EFI, make sure to set access to anyone with link for viewer in Google drive share settings. Consider donating to me through Ko-Fi if you appreciate my work here!?
mikeyworx Posted July 8, 2024 Author Posted July 8, 2024 25 minutes ago, Trijal said: I can't access your EFI, make sure to set access to anyone with link for viewer in Google drive share settings. https://drive.google.com/file/d/1-DrIXiixMJyUdY7OscjJMuqSyf9W61Tu/view my bad try it again mate thanks !
