Need Assitance for Hackintosh Hp Elitebook G5 i7-8550U CPU @ 1.80GHz
Hello i am attaching my specs below please can you let me know can i get an hackintosh on my Hp Laptop Below are the Specs attached.
Thanks Looking to archive a Hackintosh.
HP EliteBook 840 G5
3RF15UT (Recovery Media Used)
16.00 GB (15.85 GB usable)
Intel(R) Core(TM) i7-8550U CPU @ 1.80GHz
bois Q78 Ver. 01.28.00 - 04/15/2024
Yes
Have support.
bro its not woking after mounting the mod efi for my laptop which is kabey lake when i boot into start boot menu its says support/mac stuff i am trying put mac os sonoma 14.5 also tried 13 ventura.
i have followed the step and done it but no luck please help me brther i am looking for the hackintosh for long time now
With Sonoma u need change SMBIOS to MacBookPro15,1 or 2
but after the boot right the sytem doesnt boot up maldon with the help of mini partion and explorer i place the moded EFI and when i boot in start up menu to intsall the mac os gives me error support/mac
please help me with this maldon.
i want to run mac os on my laptop please
can you help me with the EFI Maldon it would be a great Help.
also see the steps i am applying
after using belena echer to make a flash drive
using mini tool parition and chaning the Letter of EFI Folder to any letter.
opening Explorrer P++ To Acess the EFI Folder and Deleting the Present EFI Folder and Replacing with the Mode Efi Downloaded.
Going to Mini Partition tool chaning back the given Letter to no letter.
Booting the Flash Drive in Star up Menu
Selecting Mac os Sonoma
but shows Support/Mac
Configured the SMBOIS to MacbookPro15,1 and tried the installation the installation gets stuck at a same spot tried 3-4 times.
attaching the screenshot for your reference please help.
IMG_0149 2.zip
Follow instructions on tutorial. Use -igfxvesa.
igfxvesa tried it but doesnt boot up on sonoma can you give me an efi folder please with the specs I have maldon ? i request you brother
the boot took 3 hours but didnt boot was stuck there for hours
No idea. Check procedure again.
