Good morning ,
I have a problem I did everything that says about opencore, I arrive in the selection menu to install the Mac OS except that after no more black screen and then nothing more forced to restart the PC manually
my configuration
ryzen 9 5900x
asus b550 xe
rx 6900 xt asrock oc formula
32gb ddr4 3600mhz
2 nvme 990 pro 2
to seasonal power supply 1000 watts
if anyone could help me please
if you need files I have the efi folder
http://82.66.16.171:46875/share/ejYF8OKkrYRHbPKY/EFI.7z
Edited by StalkJUlienFpv
Good morning ,
I managed to install ventura and configure everything, but I have another question
They suggest I switch to Sonoma. Is there a parameter or configuration necessary once I switch to Sonoma?
because they told me once you do the update you have to modify some parameter again
What wifi? Intel?
What lan card?
How you installed Ventura?
I've your same configuration and can't do anything cause i get the message "Connection Required to install Ventura"
