What is a good build for macOS  hackintosh for 300$  for a inteil build i thinking about geting about a i3 with 16Gb of ram and asuse motherbored wish one is a good build fir good hackintosh
Core i3-14100F
GigaByte H610M K DDR4 ( You need last bios/uefi version on this to work with 14th gen)
AMD RX6600
New processors no
u can use 10th gen with IGPU, but u need mobo serie 400 with no v2 or v3 version
https://www.olarila.com/topic/14351-ga-h410m-h-with-i3-10th-gen-processor-low-price-vanilla-hackintosh/
Is this good for macOS
SRock H370M-HDV LGA1151/ Intel H370/ DDR4/ SATA3&USB3.2/ Micro ATX Motherboard
Intel Core i3-10100 Desktop Processor 4 Cores up to 4.3 GHz LGA1200 (Intel 400 Series Chipset) 65W, Model Number: BX8070110100
Cooler Master MasterBox Q300L Micro-ATX Tower with Magnetic Design Dust Filter, Transparent Acrylic Side Panel, Adjustable I/O & Fully Ventilated Airflow, Black (MCB-Q300L-KANN-S00)
PSU, Continuous Power with 120mm Ultra Quiet Cooling Fan, ATX 12V V2.3/EPS 12V Active PFC Power Supply PS-SPD-0500NPCWUS-W
Corsair VENGEANCE LPX DDR4 16GB (2x8GB) 3200MHz CL16 Intel XMP 2.0 Computer Memory - Black (CMK16GX4M2E3200C16
what is is a good WiFi card with it I don’t no a good Aslo the i3 I find dose not need a gpu all these parts good for macOS 13 or for big sir?
This mobo have other socket no? Pay attention with this.
Can I build the PC without the case
Aslo dose the i3 I pick dose it need a GPU because the one I pick there’s 2 different versions of it wish version doesn’t need graphics card
Intel Core i3-10100
