Compatible? If you help quickly I will donate :D
Hi is this compatible?
  • Firebreather Beast A78X3D47TS
  • AMD Ryzen 7 7800X3D
  • Nvidia RTX 4070 Ti SUPER 16GB kaart 1TB SSD 16GB DDR5
  • 4TB Transcend Gen4 SSD 250S tot 7200MBs
Or should I buy different cpu and gpu? I want to order tonight.
Thanks so much, I will donate if you help tonight :)
My budget is 2000 - 2500 euro.
Edited by gazwho
This NVidia don't have support. Use amd GPU like rx6600, 6800 or 6900.
Hmm alright, but the AMD processor has an iGpu, will that work? I won't do heavy editing.
I will donate, thanks :)
