Hello, I have an Acemagican AM05
Mini PC with AMD Ryzen 7 5700U and an extreme WIFI problem.
I have already bought 2 cards and everything is set up absolutely correctly, but my EFI doesn't start no matter which card I use.
I use the Intel AX200 or can also use the AX210.
The cards are absolutely intact, I tested that on Windows and Linux. The card also works under Mac OS Sonoma with an EFI that I found online but is not for my system.
I have absolutely no idea how to get the cards to work with my EFI and I'm asking for help
config.plist.zip
