Thanks in advance for the time you will dedicate to me, I will be enormously grateful to you. I'll explain my situation step by step and then get to my problem.I have a Fujitsu pre-assembled PC, with 16GB of RAM, Intel i7 6700, GeForce Asus 4GB 1050 Ti GPU, A 2TB Toshiba HDD and a 250GB M.2 SSD (where I install the Olarila software).3 years ago I already installed Sierra with a file that was not in RAW format, and everything seems to have gone pretty well, currently I still work with this,I would like to use the Ventura version to be able to update.I know well that after High Sierra the new versions do not support my GPU.I managed to make the key for Ventura following this procedure
https://youtu.be/GGy3V3YT6tI?si=YSSbGm45lz-8Vlwi
after my pc I replaced my m.2 ssd with a new one so as not to lose my work and the sierra version in case of problems .
Well, I managed to have the key read with Ventura and I proceeded with the installation, I formatted the disc where I wanted to install Ventura in journaled format, it seemed to go quiet until I found the apple symbol that said 29 minutes to the installation, so it restarted by itself and I found myself a little different screen from how he showed in the video on youtube, the extra windows icon appears and instead of finding them selected after restarting automatically On the macOS icon it will install, I had to go manually and click on it, and they restarted bringing me back to the apple symbol as if it wanted to advance the loading but did not move. after 1 hour and 30 minutes of continuous reboots and always clicking on the macos symbol will install, I have not noticed any advancement under the apple, I have also clicked a few times on the symbol reset nvram But nothing to do so I sadly gave up and am desperately looking for help for this installation of Ventura AMA also in the future for new updates.I am a big fan of Olarila and thank you very much. I hope to have the most support and to solve my problem with your help. I would like to understand What did I do wrong and what to do. Also managing to install the new versions which GPU you recommend with 4 GB of performing memory and which CPU.Thanks in advance.
Manuel
images.zip
Go to AMD GPU like RX6600 and done.
So would it be enough to buy the GPU you recommended and the installation would be safely advanced until it is completed? so not even the internal GPU of my intel i7 6700 cpu helps Ventura's installation? because I tried to disconnect my 1050 ti and setting the internal one from the bios as the primary GPU But despite this, the advancement of the apple was not completed. If you confirm that all this problem is solved with the GPU you have recommended, I proceed to buy it. Finally this GPU Recommended Is it compatible from Monterey versions to the most up-to-date versions?thanks?? I will make a donation I await your reply for confirmation
I have also read that the RX6600 supports PCIe 4.0 a , my pc only has 3.0 support, do i have to change computer? thanks ??
https://www.manua.ls/fujitsu/esprimo-p756/specifications
These are the specifications of my PC, you can kindly give a visit and confirm my doubts.
On 25/4/2024 at 01:10, MaLd0n said:
Vai alla GPU AMD come RX6600 e fatto.
No problem. Just work. Just don't use chinese GPUs, use ASROCK, XFX, ASUS, GIGABYTE, POWERCOLOR
Yes. U can use Ventura or Sonoma.
2 hours ago, MaLd0n said:
Nessun problema. Solo lavoro. Basta non usare GPU cinesi, usa ASROCK, XFX, ASUS, GIGABYTE, POWERCOLOR
SÌ. Puoi usare Ventura o Sonoma.
Thanks for the time you have dedicated to me. I just donated a tip With PayPal . I hope you can always be there for me in the future.??
