Hello,
I am using macOS Sonoma with the RX 6700XT GPU. I know I need to use the NootRx.kext, I followed a tutorial where it said I need to delete whatever green from EFI folder and in config.plist and replace it with NootRX. I did that and cleared the NVRAM 2 times. MacOS gets to some point in booting and then force restarts. I have reinstalled the system 3 times. Please help.
Thanks,
Jan
