Help! Touchpad and/or touchscreen on Ryzen laptop, Levono Yoga 530-14arr
Hi, I've been trying to setup a Hackintosh for a Ryzen 5 laptop, Lenovo Yoga 530-14arr, installed Ventura with full iGpu support Vega 8 Graphics 2gb with NootedRed.kext, but I can't get my touchpad working, I tried with the NootInc VoodooI2C.kext, with different combinations of VoodooI2CHID, Synaptic, Elan, etc. I also tried it with the original VoodooI2C from opencore link, I've tried all those combinations without any additional boot arg and also with -vi2c-force-polling aswel, and never got any positive results, is there anything you can recommend to try out,  I'll attach my config.plis, the results I got from ioreg (when I created them had a USB Mouse connected) and a screenshot of my device manager in Windows.
Thanks in advance.
ioreg&config.zip
use last voodooi2c kexts with Windows patch acpi
Which patches? I made my SSDTs with SSDTTime, added to ACPI folder, and merged with the config.plis, the following patches: SSDT-EC, SSDT-HPET, SSDT-PLUG, SSDT-PNLF, SSDT-USBX and SSDT-XOSI, which patch I am missing? Thanks for your help and reply
Post EFI folder here
EFI.zip test it
35 minutes ago, MaLd0n said:
EFI.zip test it
Thanks, tested it, copying and pasting EFI folder, made NVRam reset, still no luck, the touchpad still isn't working, this is the new IOReg screenshot for what I got booting this file
IOReg new
Use this EFI 02.zip
I think u need to report it on github Voodooi2c
Follow correct instructions to report or ur files is not accept
1 hour ago, MaLd0n said:
Use this EFI 02.zip
Thanks for your help, even with this one it didn't work, so I will check out the report to Voodooi2C, if I get any response, I'll post it back here, thanks!
