I tried to install macos monterey with the generic efi for comet lake laptop but in the installation process where it says "30 minutes left" it reaches halfway and then turns off, how can I fix that?
Laptop Specs:
- I5 10210U
- 16GB DDR4 2666MHZ
- 256GB SSD SAMSUNG MZALQ256HAJD-000L1
- Display 1366 x 768
Attached The Efi
LINK: https://drive.google.com/file/d/1rLeHlieOQ8MC3nOBrltWoAwepbySwncv/view?usp=sharing
Doesnt Work
Try with other nvme with good support.
Hi it's again please a need e few help ???
i have download and replace my EFI folder with the one that you make but i now got a freezing lags with mous and also white background .
can you look at for me. i before did a few changes in the EFI folder by removing USBinjectAll.ketx and XHCI-unsuported.kext replacing by my USBtoolBox.ket that i did with Olarila tutorial and USBtool.kext.
here is the two different EFI
I have also an additional graphic card MSI GEFORCE 1070 ti that i have turn of and stick with the mother-board intel HD600
Sorry i will like to learn more much DSDT DSDT DSDT  ? I am a hold newbie geek ? and struggle a lot with DSDT.
finally i have to admit i must tri to handle DSDT cause nothing can be good without these tables ?
i no idea what to do and what order i have to place them to get them work ? my PC will die soon because reinstalling and rebooting ?
Archive 2.zip
Ps: The OpenCore-Mod efi that i use before work well unless wifi bluetooth audio and applTV etc..
Since i have load the new one things goes wrong ?, i then remove my USB config and keep USBinjectAll but still freezz
i also do reset NVRAM before every reboot
