I tried to install with the efi folder and the image of sonoma 14.2.1 as described in the post on the forum (the only one i found on the internet about this build) but when i press "Install macOS sonoma" and after some lines of advices the pc reboots; i also have a 4070 installed but i tried to install plugging the DP in the Rx 460 and also the mobo. I don't understand if this is related to the gpu, the visual exit or the wrong efi folder.
Check if ur NVME have good support. Try disable this NVIDIA.
It stops on clover and opencore first start, not on the installer in the recovery. Anyway i’m installing it not on the nvme but on another ssd where a few months ago i installed ventura so it’s fully supported.
