Hi
I am going to assemble a new Hackintosh PC i have done some research but still am afraid that i get the wrong hardware
my goal is good hardware with a Mac installed for coding and Music Productions and my budget is flexible this is the hardware that I've chosen (note: GPU is not my pirority)
Core i9-13900KS Raptor Lake LGA1700 13th Gen Box Processor
ASUS Prime Z790-A WIFI DDR5 LGA1700 13th Gen ATX Motherboard
ASUS ROG Strix RX 6600 XT Gaming OC
ASUS ROG RYUO III 360 ARGB WHITE EDITION CPU Liquid Cooler
Corsair Dominator Platinum RGB Black 64GB 32GBx2 5600MHz CL40 DDR5 Memory
Samsung 980 PRO PCIe 4.0 2280 NVMe 1TB M.2 SSD
FSP Hydro G PRO ATX3.0(PCIe5.0) 1000W GOLD Full Modular Power Supply
still haven't bought anything yet and waiting to confirm that everything works
I would appreciate it if someone gave me tips and correcting and if anything is related to coding I can get through
PS: I already have MacOS Monterey on my MacBook but I want the latest MacOS version (currently Sonama) with an almost beast hardware
Regards
Edited by Parsa Vandy
Notes
Good hardware Just change nvme. Go to Corsair MP 600 Pro XT.
Go to memory with 6000mhz +.
Thanks for the reply i would definitely go for the NVMe you suggested and for memory in order to get more than 5600 MHz I need to overclock which I don't know if it would be supported or not in hackintosh tho! 64G 5600MHz does my job pretty well but I think about it
SO! all the hardware I've mentioned will work on a Sonama Hackintosh without a problem?
U can use only two memory sticks like mine for exemple 32 or 64gb with 7000mhz or 7200mjz. Im using Patriot 7200mhz.
True! so I go for the max MHz and see what happens the cost ratio would be around 15-20% but the effort would be great
So again! does the hardware work fine without a problem?
This is perfect hackintosh.
Only change on bios/uefi is xmp to 1 or 2 and i like set TDP to 253w.
