EFI Agent - menu bar utility - Mount EFI partition
Simple, low resource, efficient and no frills tool to mount EFI partitions by headkaze
Download - EFI.Agent.zip
Features:
- Shows EFI disks to mount / unmount and open in Finder
- Shows disk icons and color-coded partition scheme
- Shows boot EFI partition (uses IODeviceTree:/chosen/boot-device-path if IODeviceTree:/options/efi-boot-device is unavailable)
- Shows link for APFS containers to physical store and vice versa
- Shows device name if media name is not available
- Mount / unmount, eject and open context menu for partition scheme table
- Tools to delete APFS container or converting HFS to APFS
- Shows notifications on disk actions
- Percentage bars show space used on mounted partitions
- Drag the position of the splitter to adjust the table views
- Launch at Login option
  • Thanks 3
Hi Guys,
EFI Agent is a convenient menu bar utility for macOS that simplifies the process of mounting the EFI partition. It provides quick access to EFI partition management, allowing users to effortlessly modify or inspect their system's EFI settings. A handy tool for those needing easy and efficient EFI partition access and management.
On 7/15/2024 at 4:33 PM, Hendrix02 said:
Hi Guys,
  Fnaf 1
You are quite knowledgeable about EFI Agent. Thanks to you I understand it more
great tool thank you
Asus Vivobook X512DA Ventura 13.5 (ventura works like a charm)
Lenovo ideapad Z710 on sequoia 15.7
Desktop: Asus Z97-C|CPU intel i7 4770K|Nvidia GT 720 2GB|Sequoia 15.6.1| OC 1.0.6
Iphone 14 128GB ios 26
On 7/15/2024 at 6:33 AM, Hendrix02 said:
Hi Guys,
What specific features of the EFI.Agenttool do you find most useful for managing EFI partitions?
