How can I fix the error under MacOS Venture?
I installed Ventura, the first step worked perfectly, the second step also. Now that it is no longer MacOS Installer but VenturaHD, which I named as such during the process, the system is now in a boot loop.
Everything works perfectly under Monterey.
I use the Preconfigured Version of OpenCore. The EFI is attached. =>  https://drive.google.com/file/d/1BaHkcz8WxGaSwTJOEKEcbp1JpI9HLyQG/view?usp=sharing
What hardware?
These GPUs don't work on ventura
