Processor : 13th Generation Intel® Core™ i5-1335U (12 MB cache, 10 cores, 12 threads, up to 4.60 GHz)
GPU Intel® Iris® Xe Graphics
LAN Intel® Wi-Fi 6E AX211, 2x2, 802.11ax, Bluetooth® wireless card
I Know GPU don't Support but we need just MacOS For Application. That application don't need GPU support  Please help with this just need to boot and Lan, keyboard and trackpad
Do u tried this efi folder? -Desktop AlderLake and RaptorLake Download HERE
https://easyupload.io/ndgq86
-Last Bios UEFI Version
U need generate UTBMap.kext
Post this kext here
Check if have hide options
Use one nvme and test
