Random beach ball for minutes every 5 minutes, freeze and rebooting
Hello,
I am having this issue for a couple of weeks now. It's weird because it just started recently, but I haven't used Hackintosh that much lately so maybe this statement is not really reliable.
Well, my Hackintosh is essentially not usable, every few seconds it start beach balling a lot, whatever I'm doing, can be ableton, can be chrome or just the finder. It simply freezes and I can move The cursor which is the beach ball And just stay like that. Sometimes for minutes, sometimes for seconds. Other than this, often it just froze, the cursor as well, and reboot. Another weird thing, sometimes it just bring s me back to the login screen like it rebooted but without showing all the boot process.
I have no idea why it's happening, other than this the desktop have all the functionality (usb, blue tooth, wifi, etc) working fine. I'm also pretty sure that this started happening a few days ago, because i had a music session 2 weeks ago and was not that bad. But nothing changed since then.
My specs are:
Gigabyte z790 aorus elite ax
Intel 13600kf
AMD 6950xt
4 ssd, every of them looks healthy. The one with macos installed is a Kingston nv2.
Thanks guys
@MaLd0n
Edited by orbee
Kingston is not good for macos. I think this problem is that.
11 hours ago, MaLd0n said:
Kingston is not good for macros. I think this problem is that.
Hey @MaLd0n, always used that kingston with my prev configuration and was working perfectly.
I fixed the usb ports but still working bad, beachballing and getting stuck. Can you please take a look at the efi?
https://easyupload.io/qsmcyb
Thanks!
Use Olarila efi folder for ur hardware with ur SSDT-6950XT-73A5-GPU-SPOOF
