Hello Hackintosh Community! I'm a beginner attempting to install Hackintosh on my system, but I've encountered an issue during the boot process. When I boot into the USB, the commands run, and after a few seconds, the screen goes off, and nothing happens.
System Specifications:
Motherboard: HP 82DD
CPU: Intel Core i3 7100u Kaby Lake
GPU: Integrated GPU Intel HD 620
RAM: 8GB DDR4
Audio Codec: Realtek High Definition
Storage: 1TB HDD, 500GB SATA SSD
Ethernet Card: Realtek GbE Family Controller
Installation Details: macOS Version: Big Sur 11.7.10
Guide Followed: FreeCodeCamp Guide - which is based on the Dortania OpenCore Guide
Issue Description: After following the guide meticulously, the commands run during boot from the USB, but the screen goes off after a few seconds, and the PC seems unresponsive.
BIOS Settings: Secure Boot off, Clear Secure Keys on, Virtualization disabled
EFI Folder: [Attached Zip File]
Additional Information: Monitor works on integrated GPU (iGPU), and imUnfamiliar with BIOS settings, and they differ from the guide
Additional Device Details: Device Specs
As a beginner, I would appreciate clear explanations and guidance to troubleshoot and resolve this issue. Any assistance you can provide will be immensely helpful. Thank you in advance for taking the time to read my post and for your valuable assistance. I'm eager to get my Hackintosh up and running smoothly!
