Mainboard Gigabyte H410M H V2 Intel H470 (Comet Lake PCH-H)
Cpu i5 10400 _SB.PR00 Comet Lake-S 6 core
Gpu UHD 630 PCI\VEN_8086&DEV_9BC5&SUBSYS_D0001458&REV_05 _SB.PCI0.GFX0
when i use user efi folder, but after choosing the install option in opencore and waiting for the command line, I get a black screen.
Edited by Alex Shanto
-Bios/UEFI in full default settings(Just change CSM to Disable if you have a AMD GPU and Sata to Ahci)
