Hello, i need some help.
I successfully Installed on my Fujitsu Esprimo P556/E90+ Monterey with the Modded EFi. My Specs are Intel Core I3-6100, 8GB Crucial DDR4, Intenso SSD Performance with 250GB. I dont have a dedicated GPU.
My Mainboard only have DVI and DP. I try that both Monitors working on the same time. I spend over 2 Weeks that my DVI Port is kinda working but and the Monitor with DP Connected is showing as connected but i have a Blackscreen. If i reboot i only see on my DVI Monitor the Screen but the Main screen should be on DP. I try a lot with Hackintool but i dont get it running, Is someone having the same Problems that the 2nd Screen dont run ? Maybe someone can help me. My EFI Folder is attached to this post. After fixing the 2nd monitor stuff i´ll add all aditional thinks like SSDT and the other stuff. My Sound is working.
Downloadlink EFI Folder : https://www.file-upload.net/download-15239385/EFI.zip.html
Hello MaLd0n thanks for your reply. I tried to understand the guide from Whatevergreen but I think I’m to stupid to understand it. I’m sure it would work but I don’t understand it, I’m new to hackintosh. I’m happy that my IGPU have full acceleration, it’s only the connector problem.
My major problem is, I need a running double Monitor setup, I can pay for it if you want but I need some help with that. I only have the DP and Digital DVI on my System running.
