Hackintosh EFI OpenCore Surface Pro 6
-Problems with Paypal HERE
-Installation Guide HERE
-Hackintosh EFI folders HERE
-Hackintosh USB Remap HERE
Download EFI Folder EFI Surface Pro 6.zip
Install IPTSDaemon HERE
Credits to Xiashangning for BigSurface.kext
We're all here to have fun and learn from each other! That's all Folks!
Credits:
Wifi/bt need broadcom or Intel
Sleep doesnt work corretly. PreventUserIdleSystemSleep named: "com.apple.bluetooth.bluetool.script". Someone have any ideas?
--Update EFI folder in first post--
Kexts and bootloader to last version
Thanks for the EFI folder! How can the internal bluetooth module be disabled? The bluetooth keeps turning off in settings, because it's trying to use the internal Marvell chip I think. Do I need to remap the usb ports for this?
Just kill this usb port
Can you explain how I can do this? I can't discover on which port the internal bluetooth is mapped. I used IORegistryExplorer and HackinTool, but can't find anything other than the surface type cover. But In HackinTool, I can see this bluetooth device under System > Peripherals:spacer.png
What is this device?
U need. check ioreg what port and delete this por then generate kext
1 hour ago, wingjson said:
HI,thank you for this edit,and does it support macos15 sequoia
Update for sequoia in first post
