Vega 64 fan not running on Sonoma install
Hello, I have got my Asus Prime Z390A up and running with Sonoma but am having an issue with my Asus Vega64 graphics card. The fans refuse to come on and run and it is causing a black screen and I have to shut the system down. The fans work fine in Windows but the will not run on the Mac OS Sonoma. Any ideas on how to resolve this issue?
Z77 Build= Quad Boot Win 10, Win 7, Mojave, Kali Linux (learning). 2x NVME drives, 1X Samsung EVO SSD, 1X 16GB USB 3.0 (Kali) 1X 1TB WD storage drive, GTX770, 16GB Gskill ARES,
Work in progress1: P35-DS3R,  Xeon 3360 @3.2GHz. 8GB ddr2 800, Tri-Boot system.
Work in progress2: G31M-ES2L, Q9650 @ 3.2GHz. 4GB ddr2 800, Tri-Boot system
Waiting on case for next build.....
Use this app https://olarila.com/files/Utils/VGTab_en_v0.4.zip to generate VegaTab_64.kext.
Change temp to 58 for example and fan start on this temp
Does it have the install instructions for the Kext it generates?
I try to open the app and it tells me that it can only be used on OS 10.13 and later and I am unable to go any further. as it only displays an exit button
Disable security on safari. just work fine here on sonoma and kext is generated
