Fujitsu E5410 - Newbie Help?
Hello dear HackInTosh Community,
I am a newcomer to the HackInTosh world.
My first project is this notebook, which I used with the help of a "prefabricated" EFI folder.
Since I'm not learning anything this way, I wanted to ask you if you can tell me which kext are for what exactly and if I need them at all?
I also have two problems.
1)
With my trackpad I can only left click, right click does not work, also I have to have a finger on the trackpad to click.
How can I fix this?
2)
I cannot use the brightness of my display with the function keys F7 and F8.
I can mute the volume with F2, turn down F3 and turn up F4.
Many thanks to all who would like to help me.
config.plist.zip
What hardware specs? Post efi folder here.
Hardware: Fujitsu E5410, i5 10210U, Intel UHD 620, 16GB DDR4 RAM, 512GB Crucial NVMe, Intel Wi-Fi 6 AX201
EFI Folder: https://easyupload.io/a9oygu
Trackpad rect click works, was due to Sonoma settings, display brightness as well.Now the question remains as to which keys I really need for the device and why I need them or what they do.
