How to create SSDTs for Hackintosh - Easy way with SSDTTime
Easy way to create SSDTs for Hackintosh with SSDTTime
-Problems with Paypal HERE
-Installation Guide HERE
-Hackintosh EFI folders HERE
-Hackintosh USB Remap HERE
Download this tool to generate SSDTs SSDTTime.zip Credits for this tool CorpNewt
Download this tool to extract DSDT under macOS ACPI Extractor.zip
1- Run SSDTTime.bat under Windows or SSDTTime.command under macOS
2- Extracting DSDT
2a) On Windows just press P with SSDTTime file above
2b) On macOS use ACPI Extractor.zip and ACPI.zip is generated on desktop with all tables
3- HPET - Patching IRQ conflicts
4- EC - Fake Embedded controller (Desktop and Laptops)
5- USBX - USB power properties
6- PLUG - Set plugin-type = 1 for Power Management
7- PMC - Creating missing PMCR device for native NVRAM on Coffee Lake+
8- AWAC - Disable AWAC on Coffee Lake+
9- USB-Reset - Returns a zero status for detected root hubs to allow hardware querying
10- PNLF - Device for laptop backlight control (Need inject correct properties for your hardware. Check images bellow)
11- XOSI - _OSI rename and patch to return true for a range of Windows versions (Use Auto-Detect)
All files is generated on Results folder. You need to put SSDTs with .aml extension in ACPI bootloader folder
You need apply patches on your config.plist on ACPI/Patch tab (Check images bellow)
Credits:
CorpNewt, NoOne, Slice, Kabyl, usr-sse2, jadran, Blackosx, dmazar, STLVNUB, pcj, apianti, JrCs, pene, FrodoKenny, skoczy, ycr.ru, Oscar09, xsmile, SoThOr, RehabMan, Download-Fritz, Zenit432, cecekpawon, Intel, Apple, Oracle, Chameleon Team, crazybirdy, Mieze, Mirone, Oldnapalm, netkas, Elconiglio, artut-pt, ErmaC, Pavo, Toleda, Master Chief and family, bcc9, The King, PMheart, Sherlocks, Micky1979, vit9696, vandroiy2013, Voodoo Team, Pike R. Alpha, lvs1974, Austere.J, CVad, headkaze, onemanosx, erroruser, Jenny David, Sampath007, Facebook Hackintosh community, Facebook Olarila community and many, many, many others!
We're all here to have fun and learn from each other! That's all Folks!
  • Like 4
On 8/23/2024 at 3:09 PM, max icewind said:
tambem ten por linux ubuntu? esse ssdt time?
Sim. Com o SSDTTime.py.
