i5-12400F is litmit power consumption at 40w
I have built my hackintosh with spec:
Quote
  • Mainboard: Asus ROG B760-G WIFI D4
  • CPU: Intel i5-12400F
  • GPU: Asrock RX5600
  • RAM: TridentZ 64GB 3200
Everything is working great in the lastest ventura version except the CPU. I ran the cinebench benchmark but the iStat display the power consumption max at 40W and the temperature not higher 45 celcius.
This is my runme.zip
How to fix this problem?
EFI.zip
-Bios/UEFI in full default settings(CSM to Disable with AMD GPU - Sata to Ahci - Secure Boot Disable on mobiles)
thanks
2 hours ago, MaLd0n said:
EFI.zip
